I need help regarding beam supported composite slab.
According AISC manual 14th edition it is not recommended to use Y2>7. So AISC recommendation not to use more than W16x45 for the depth of 16'' beam & there is no value given for size more than W16x45 in table 3-19. But RISA floor and Enercalc is giving sizes more than W16X45. For Architect requirement I can not use beam size more than 16". So Which recommendation should I use and why?
RE: I need help regarding beam supported composite slab.
The location "7" is the point where ΣQn = 0.25FyAs. This is a very low PNA position and represents a composite beam with 25% composite behavior which has historically been the lower bound limit of composite shapes.
In other words, below 25% you are not adequately engaging the concrete - you would get substantial slip between the steel and concrete and this could significantly affect your overall stiffness of the slab-beam.
Read the commentary in the AISC specification (section I3.2 - page 16.1-355 and through 356). They outline some of the concerns of using lower composite action.
Hope this helps!
If you are limited to 16" then heavier W16's could be used. The table nor the spec prohibits that from what I can see.
