ASME B31.4 Equation 402.6.2 SI Units
Hi All,
The axial stress in the above equation (=Fa/A) calls up the axial force (Fa) in Newtons while the pipe cross sectional area (A) is called up as cm2. The resulting longitudinal stress is supposed to be in MPa which it isn't.
Am I missing something here?
Thanks in anticipation.
RE: ASME B31.4 Equation 402.6.2 SI Units
All the imperial units end up the same (psi), but the metric ones are MPa and KPa which doesn't look right.
Might be worth a technical inquiry (see non mandatory appendix A of the code - right at the back)
Could be everyone just uses mathcad which automatically sorts it out, or Caesar....
LI
Need some clarificaion around what pressures to use for modeling in Autopipe.
Our pump operating pressure is about 340m (dead head 400m). The thermal relief valves setting is set at 400m (hydrocarbon duty).
What pressure should be used in the model in conjunction with the seismic loads?
Thanks in advance.
Thanks for coming back and updating us all.
