Whats the affect of loaded trolley
Whats the affect of loaded trolley on flange?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Whats the affect of loaded trolley
Dik
Here are two documents I found that helped with the design:
1) ANSI Specification For Patented Track Underhung Cranes & Monorail MH21.1-2009
2) ASME B30.11-2010 Monorails & Underhung Cranes
I think both documents can be found on internet for free with a little searching.
The ASME document has good background info, but The ANSI document was a little more useful because it actually specifies some loading rules.
Calculation of an impact load
Skewing of load
Allowable stress in compression flange
Allowable tension stress in flange
