Help with Planetary Gear Arrangement
Hi all,
Need help with a Gear Train described below. A rough sketch is attached.
1)We have a Round Plate above which there is a 88 Teeth Gear (Gear A). Both have their own drive and the ratio is 1:4. For every 1 turn of the plate, the Gear A rotates 4 times. They both rotate in the same clockwise direction.
2)On the plate is mounted a Gear B which meshes with the 88 Tooth Gear A.
I want it such that for every 1 rotation of the Plate, the Gear B rotates 18 times.
I am unable to figure out the no. of Teeth for Gear B, and would be grateful for any help with the formula/calculation.
If required, I can change the ratio between the Plate and the Gear A and/or the No. of Teeth on Gear A.
RE: Help with Planetary Gear Arrangement
That's not really a planetary gear system.
If gear B rotates 18 times for each rotation of the plate, it rotates 18/4 times for each rotation of gear A. You need 88teeth/18×4=19.6teeth, approximately. It will rotate in the opposite direction. If you want to turn exactly 18 times per turn of the plate, you need gears with 90 teeth and 20 teeth, respectively.
This is not very complicated.
JHG
Thanks for your reply. We did a simulation in solidworks with the 90-20 Teeth Combination and it didn't work. The number of rotations of Gear B don't remain constant with every rotation of the plate.
If you have a gear train of any kind with round gears in constant mesh, the output gear should rotate at a constant rate. If your output is varying, something else is moving.
JHG
It gives us approx. 13.5 revolutions
What worked is 90-15 combination. It gives us exact 18. Thanks.
