machining time formula
please send me the machining time calculation formula for turning,milling,grinding
RE: machining time formula
#26 Machinery's Handbook - pag.983.....
Have fun!
Attitude is everything!
Ah, Grasshopper, no one knows.  You must find the answer within you.
Or
The best you find anywhere is a starting point.  Materials are different and different pieces of the same material can be different.  Machines are different.  In some processes weather can make a difference.  There can be a difference between Monday morning procedures and Tuesday afternoon procedures.
It is horribly complicated and the more precise you get the more complicated it becomes.
There is a real reason you need, highly skilled, expensive people to run “automatic” machines.
Tom
You might want to try The Handbook of Machining and Metalworking Calculations
Author: Ron A. Walsh  Cost = $319.95  You can find it at http://www.the-bookshelf.com/sc-tec/0071360662.htm or any technical bookstore should be able to get it for you.
you might look the handbook of machining.
author: Boothroy.
this´s a excellent book for this item. you can learn many things about machining and tools machines.
