wiring on/off switch to electric motor
I have a single phase, 115V electric motor that is connected to a fuel pump/junction box as shown in the attached wiring diagram on the top left. Normally they are shipped with the three leads (black, white, and brown) hanging loosely so the customer can install the motor and connect wiring themselves.
I'm interested in having the motor used in a different application (as a portable oil transfer pump), so it would not be be wired to a box. Instead, it would have a 3-prong connector and a on/off toggle switch. How would I connect these two things to the current motor? What would I need? I'm not very electrically inclined so I'd appreciate any input.
RE: wiring on/off switch to electric motor
Hire an electrician with experience with hazardous locations.
Bill
"Why not the best?"
Jimmy Carter
