NX bitmap name for the "red asterix" in NX dialogs
Hi -
I'm right now programming a small tool for NX...
This program also contains a dialog (BlockStyler) and in this dialog I use some bitmaps....
But I also need the NX bitmap " the red Asterix" used in many NX dialogs....please see attached screenshot...
I all ready use the green checkmark - also used in many NX dialogs...this bitmap name is "Check"...works pretty well...
Do any of you guys , know the name of this NX bitmap " the red Asterix"...?
lklo
RE: NX bitmap name for the "red asterix" in NX dialogs
Isn't that automatically showing when there is nothing selected yet?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
asterisk
If you ever want the name of an bitmap you see in an NX dialog, temporarily set the environment variable PRINT_DIALOG_BITMAP_NAMES=1, which records them in the syslog.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
The NX9 bitmaps were posted here awhile back, not sure if they are still available
Hi Guys -
thank you so much for your help here...
I simply tried to set variable PRINT_DIALOG_BITMAP_NAMES=1 , and now every used bitmap in session is logged in syslog...
I found the bitmaps I needed to my program...
lklo
