2017 Edition of the Boiler and Pressure Vessel Code is Available
I'm not sure if IHS or other providers has it available yet, but you can order directly from ASME. Lots of changes this time around. I am working on a blog post to summarize the changes in VIII-1 and VIII-2.
RE: 2017 Edition of the Boiler and Pressure Vessel Code is Available
The Dutch standardisation institute NEN, where you can purchase these standards (amongst others), has the BPV 2017 available as well.
I downloaded the Code books from IHS today.
Checking today, Techstreet has the codes available, but lists the redline versions as "Coming Soon".
I won't even look at the new codes until the redlines are available. It's almost impossible to meaningfully see all of the changes without them.
