Macro to add arrow in Cat drawing (Change thickness)
I am new to automation in Catia and I need help . I need to automatically generate drawings containing arrows. So far everything works fine except for thethickness of the arrows.
I have used
Set MyArrow1 = MyDrawingViews.ActiveView.Arrows.Add(X1 coord, Y1 coord, X2 coord, Y2 coord)
to create the arrow, but I need to increase its thickness.
Can someone help me with the command to use to change the thickness of an arrow in a catdrawing? After many researches on the Internet I cannot find a way.
Thanking you in advance.
I have used
RE: Macro to add arrow in Cat drawing (Change thickness)
CODE -->
selection1.Add (MyArrow1 ) CATIA.ActiveDocument.Selection.VisProperties.SetRealWidth 2, 1 CATIA.ActiveDocument.Selection.ClearNumber 2 is the number of the item of the thickness.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
Set MyArrow1 = MyDrawingViews.ActiveView.Arrows.Add(x1,y1,x2,y2)
CATIA.ActiveDocument.Selection.Add MyArrow1
Tiago Figueiredo
Tooling Engineer
Youtube channel:
