Broken view in revolved section
Hello
Can we give view break in revolved section.
Because i am unable to give view break in revolved section
Please help me out from this.
RE: Broken view in revolved section
Do you get an error message of some kind?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Actually after taking view break command unable to select the viEW which we want to brak
NX9 / TC10.1.2
It would be very difficult to determine what the cause is without an example
NX9 / TC10.1.2
Give one view in drafting environment and create a revolved section and try to view break the section view.
I am unable to do that try at your end if possible
You can do that with an illustration such as an image, or a NX demonstration example if you have restrictions on your production drawings.
Because we do not understand what the problem is, it does not help that "you can try that at your nx also".
Tomas
Please check the snapshot in attached file.for reference
Deepankar
Only quick and dirty solution would be is to create the revolved section view twice (hide the second section line) and as such create the broken view yourself.
NX9 / TC10.1.2
