Distributed Generation problem
Problem:
Alternator Rotor winding failure (Turn to turn.) only on 400volt machines in parallel with grid. Not on high voltage machines on same installation. (Rotor construction identical.)
Site conditions:
Very weak grid, with lots of loss of mains.
Lots of power factor correction. (Capacitive.)
Lots of underexcitation trips due to power factor being in the unstable zone, presumably after loss of mains.
Rotor winding is protected by a varister. (No failures.)
Failure could be caused by induced voltage from surges in stator?? (AC on DC circuit???)
Any ideas or suggestions as to why only LV machines?
Site conditions:
RE: Distributed Generation problem
Blacksmith
