CSHEAR Element Output
Dear All,
I looking at the nastran output of shear panel element CSHEAR and I confused with the Shear-IJ output, where I=1..4, J=1..4
Example: So Shear-IJ, what units it has? lb/in? Also what is kick output? Thanks. Kristina.
Sorry about how it looks, when I paste it it shows good format but preview does not show good format.
F O R C E S A C T I N G O N S H E A R P A N E L E L E M E N T S (CSHEAR)
====== POINT 1 ====== ====== POINT 2 ====== ====== POINT 3 ====== ====== POINT 4 ======
ELEMENT F-FROM-4 F-FROM-2 F-FROM-1 F-FROM-3 F-FROM-2 F-FROM-4 F-FROM-3 F-FROM-1
ID KICK-1 SHEAR-12 KICK-2 SHEAR-23 KICK-3 SHEAR-34 KICK-4 SHEAR-41
0 40069 2.50181E+02 4.25804E+01 -1.47293E+02 2.94144E+00 1.22708E+02 2.62269E+01 -1.63647E+02 1.30414E+02
0.0 2.92114E+01 0.0 2.92114E+01 0.0 2.92114E+01 0.0 2.92114E+01
RE: CSHEAR Element Output
i pretty sure they are lbs/in (thk) ... forces from NASTRAN tend to be that.
to be sure, either run a test case, or it should be in the manual
Thank you all for respond. I check NXNastran user guide, pages 897 and 913.
Page 897, section 7.2 say "All items are element forces (or moments) unless otherwise indicated".
Page 913 shows CSHEAR O/P, only list all items, and Shear-IJ is real number magnitude (RM). That's why I confuse.
rb1957 Sir, can you give me example of test case? One element and how to set up and what to check?
there are so many ways to create a shear test ... a simple shear panel, a tube in torsion, a web in bending ...
an example ..
take 1 CSHEAR element, say 2" square and 0.05" thk
surround it with RODs,
constrain 1 edge (2 nodes) to restrain rigid body motion,
load the opposite edge, in-plane, some load
then verify shear stress = element force/thk.
Thank you rb1957 Sir, I try what you say, 2.0" element bottom edge pinned, top edge total load 1Lbf to right, and I check the f06 file.
I see this now:
0 5 -5.00000E-01 -5.00000E-01 5.00000E-01 5.00000E-01 -5.00000E-01 -5.00000E-01 5.00000E-01 5.00000E-01
0.0 -5.00000E-01 0.0 -5.00000E-01 0.0 -5.00000E-01 0.0 -5.00000E-01
Element is like below (corner nodes 1234, middle rod elements 1234, and CSHEAR 5):
---------3
4 ======= 3 --> 1 lbf
4[-------5-----]2
1 ======= 2
---------1
In first try I make 1.0" square element, then Shear-12 was 1.0.
Next I increase size to 2.0" same load and constraint, now Shear-12 is 0.5, so I think it is lb/in.
Shear-12 = (End Load 1 + End Load 2)/L where L=2.0" now.
Shear-12 = (0.5 + 0.5)/2 = 0.5 lb/in
I also check element max shear stress:
S T R E S S E S I N S H E A R P A N E L S ( C S H E A R )
ELEMENT MAX AVG SAFETY ELEMENT MAX AVG SAFETY
ID. SHEAR SHEAR MARGIN ID. SHEAR SHEAR MARGIN
5 3.125000E+01 -3.125000E+01
So shear flow using max shear = 31.25 psi*t, where t = 0.016"
q = 31.25*0.016 = 0.5 lb/in
But I don't understand the signs, can you help?
Also, I apply 1lbf at top right, but below is rod forces:
F O R C E S I N R O D E L E M E N T S ( C R O D )
ELEMENT AXIAL ELEMENT AXIAL
ID. FORCE TORQUE ID. FORCE TORQUE
1 0.0 0.0 2 -5.000000E-01 0.0
3 0.0 0.0 4 5.000000E-01 0.0
Why only 0.5lbf in right and left rods and no load in top rod? I understand no load in bottom rod pinned.
well you've found an error in my original response ... element force = load/length (which follows from stress = element force/thk).
carefully read sign conventions in the NASTRAN manual, sometimes the +ve sense is determined by the node numbers, sometime by the node sequence, sometimes by the co-ord system.
rod forces ... draw a FBD ... how are you applying the load ? (1/2 to each corner ? then the rod is doing nothing)
the element between the constraints probably also (particularly if over-constrained)
the other two sides need to react load to preserve moment balance, considering the moment about the constraints from the load (yes?)
OK I clear now.
I apply 1 Lbf at top edge. OK that is also clear now, nastran apply 0.5 lbf at each top node so no load in rod.
Yes, moment balance also I get, bottom left node 1.0lbf Down reaction, and bottom right node Up reaction.
Thank you very much.
