Clearance/movement between internal external threads
Hi
I have a design where I have one dowel and one threaded hole.
I want to work out what the tolerance on the centre distance needs to be so I need to work out how much the screw can move in the hole, as the part is being wound up and down (adjusted) on the screw.
I know this is different for different classes of fit for the screw but I can't seem to find a clear answer. Essentially the more free play there is between the screw and threaded hole the less tight the tolerance on the centre distance needs to be. However I don't want specify a loose class of fit if I can avoid it.
This is the same as knowing the movement of a shaft in a clearance hole except for a screw in a threaded hole.
Cheers
Cheers
RE: Clearance/movement between internal external threads
I.e., it's basically a sophomore kinematics problem, like the monkey/clown that jumps and grabs a stick, with the further complication that the driving force is offset by the center distance.
Mike Halloran
Pembroke Pines, FL, USA
Not so much under cantilever/moment load.
Mike Halloran
You might want to provide a sketch of your assembly, or at least the relevant portion.
What type of screw thread are you using?
pylfrm
You are on the right track that the class of fit will dictate the maximum movement of a screw shaft relative to a hole. It all has to do with pitch diameter and how much that is allowed to vary (which is defined by fit class i.e. 2A/2B).
For example, from ASME B1.1 a 4-40 2A screw has a pitch diameter .0950/.0925 and a 4-40 2B hole has a pitch diameter .0991/.0958. The most that screw can shift from hole center is (.0991 - .0925)/2 = .0033.
Here's an article on the topic: Threads - Long Engagement Problems (pdf)
