AddComponentsFromFiles using VB.NET
Been looking into using VB.NET and Visual Studio (2017) to control an (semi-)automation application in CATIA v5 (running R24).
Up until recently, things were going well, “transferring” code from VBA in Catia to Visual Studio; but now I ran into some issues with adding CATparts to a CATProduct (i.e., assembly).
Upon trying to use AddComponentsFromFiles I get stuck. One thing I notice is that the Variant type that is used in VBA has been deleted from VB.NET, and so the tooltip says it’s an Array type now.
In VBA, the standard procedure (i.e., macro recording) is to use:
Sub CATMain()
Dim productDocument1 As ProductDocument
Set productDocument1 = CATIA.ActiveDocument
Dim product1 As Product
Set product1 = productDocument1.Product
Dim products1 As Products
Set products1 = product1.Products
Dim arrayOfVariantOfBSTR1(0)
arrayOfVariantOfBSTR1(0) = "C:\temp\test-cylinder.CATPart"
Set products1Variant = products1
products1Variant.AddComponentsFromFiles arrayOfVariantOfBSTR1, "All"
End Sub
However, when I transfer – in every which way I can think of including putting the file name into an Array type – I get different types of errors, but no real indication of a way forwards.
Anyone tried anything similar / can point me in some direction?
Thanks.
Sub CATMain()
End Sub
Thanks.
RE: AddComponentsFromFiles using VB.NET
CODE --> VB.NET
Tesak
http://scripts4all.eu/txtoncurve/ - Text along a curve for Catia V5
(I probably messed up either definition of product1/productDocument1/products1 by explicitly defining their type..)
Thanks for the clarification!! :)
Just in case, I have used the vs2017, and a few days ago, i downgraded to VS comunity 2013. And almost everything converts from vba to vb.net.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
https://www.youtube.com/channel/UC1qdlBeJJEgMgpPLV...
