Cooling rate during PWHT
Hi..
In a header assembly of diff thickness/size materials; which has to be heat treated inside a furnace, how to determine the cooling rate.?
How the code addresses deviations in cooling rate / heating rate? Any code references pl.
RE: Cooling rate during PWHT
ASME Sec. VIII Div. 1 - See UCS - 56 (d)
B31.3 - See 331.1.4
B31.1 - See 132.5
These paragraphs talk about a maximum rate of heating and cooling based on maximum thickness.....or 1/2 of max thickness for piping codes. Using max thickness will result in the cooling rate for thinner materials being slower than required, but that should not be a concern.....I say should not, as there are no thicknesses or materials mentioned.
I have a header pipe with D606/~70mm thickness to which pipes of ~15mm & few nos of 5mm thick are welded.
All are P1 materials. How do i fix the soaking time? as my main pipe, dished end, stub etc are varying in thickness.
I have a lug of approx 40mm thick welded which is P5 material as well. How should i decide my PWHT cycle involving many materials / thicknesses ?
Secondly, while doing HT with 6 TCs, kindly clarify
During heating, if 1 thermocouple over shoots allowable rate of heating, whether it is allowed? What to do?
if 1 thermocouple drops temp by say 10deg in 10 min, & then regain heating whether it is allowed>
if 1 thermocouple overshoots allowable rate of heating for say 15 min, & then maintains very slow heating such that, hourly rate is maintained, is that allowed?
During soaking, if 1 thermocouple overshoots / drops the holding temperature , is it allowed? What to do in this case?
During cooling, if 1 thermocouple over shoots allowable rate of cooling, whether it is allowed? What to do?
if 1 thermocouple raised temp by say 10deg in 10 min, & then regain cooling whether it is allowed>
if 1 thermocouple overshoots allowable rate of cooling for say 15 min, & then maintains very slow cooling such that, hourly rate is maintained, is that allowed?
In big furnaces controlled manually, these kind of deviations bound to happen. Which code addresses these small issues? or where it is specified to ignore such deviations and that it doesnt affect quality of product?
Another issue for furnaces is temperature unbalances in the furnace.
Just commenting since you are the best on this subjects.
General Blr. CA,USA
See PW-39
Holding Temp. (min) = 600~650C
Holding time = thickness of weld/25
Max. Heating Rate = 75C
Max. Cooling Rate = 95C
this is based on my experience
