Pipe support lift off
Here's a question for B31.1 and B31.3 piping designers.
Under some load cases (usually thermal) a pipe can lift of a support and be left hanging in the air.
B31.3 has rules (Appendix P, example S302) for dealing with this situation but not B31.1.
Should prudent B31.1 piping designers..
1. ignore the lift off and accept the calculations for thermal range and cold gravity loads.
2. apply B31.3 like rules and remove the lifted off support from the gravity case.
Does the B31.1 committee lag behind the B31.3 committee or does B31.1 not have as many rules because of the more conservative allowable stresses etc.
RE: Pipe support lift off
It seems to me that if you design the pipe configuration properly the first time for the correct support and flexibility you would not have "lift-off".
Sometimes its possible to do all the right things and still get bad results
How much is the liftoff and are you sure that the support should not be a spring hanger ??
MJCronin
Sr. Process Engineer
I agree lift off should not be ignored. I was interested in why one code tells us this and how to design for it and other does not.
It is because of two separate committees who oversee B31.1 and B31.3.
Curtis
