Add body to reference set
Hello every one,
I'm trying to write journal which selected body:
- change translucency to 60
- change line to dashed
- put it on layer 100
- and finally put it in reference set "false"
First 3 point work perfect but the last one not. Below is my code:
I receive an error in line:
I tried many different ways but no one has worked. Any one can help me to solve this problem?
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports System.Collections
Imports System.Collections.Generic
Module Ref_False
Dim theSession As Session = Session.GetSession()
Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager
Dim myRefSetNames As New List(Of String)
Dim ref_temp as ReferenceSet
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
Sub Main()
Dim referenceSet1 As ReferenceSet
Dim selectedObjectsArray() As NXObject
Selectbody(selectedObjectsArray)
Dim BodyArray(selectedObjectsArray.Length - 1) As DisplayableObject
For i As Integer = 0 To selectedObjectsArray.Length - 1
BodyArray(i) = CType(selectedObjectsArray(i), DisplayableObject)
Next
If IsNothing(theSession.Parts.BaseWork) Then
'active part required
Return
End If
myRefSetNames.Add("FALSE")
For Each tempRefSetName As String In myRefSetNames
Dim refSetExists As Boolean = False
For Each tempRefSet As ReferenceSet In workPart.GetAllReferenceSets
If tempRefSet.Name.ToUpper = tempRefSetName.ToUpper Then
refSetExists = True
End If
If tempRefSet.Name.ToUpper() = "FALSE" Then
ref_temp = tempRefSet
ref_temp.SetAddComponentsAutomatically(true, true)
end if
Next
If refSetExists Then
referenceSet1.AddObjectsToReferenceSet(BodyArray)
Else
referenceSet1 = workPart.CreateReferenceSet()
referenceSet1.SetName(tempRefSetName)
referenceSet1.SetAddComponentsAutomatically(True, True)
End If
Next
myRefSetNames.clear()
Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification()
With changeBodytransluency
.ApplyToAllFaces = true
.NewTranslucency = 60
.NewFont = NXOpen.DisplayableObject.ObjectFont.Dashed
.NewLayer = 100
.Apply(bodyArray)
.Dispose()
End With
End Sub
Sub Selectbody(ByRef selectedObjects As NXObject())
Dim ui As UI = NXOpen.UI.GetUI
Dim message As String = "Select body"
Dim title As String = "Selection"
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim keepHighlighted As Boolean = False
Dim includeFeatures As Boolean = False
Dim response As Selection.Response
Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim selectionMask_array(1) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_component_type
.Subtype = UFConstants.UF_component_subtype
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
With selectionMask_array(1)
.Type = UFConstants.UF_solid_type
.Subtype = 0
End with
response = ui.SelectionManager.SelectObjects(message, title, scope, _
selectionAction, includeFeatures, _
keepHighlighted, selectionMask_array, _
selectedObjects)
If response = Selection.Response.Cancel Or response = Selection.Response.Back Then
Return
End If
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY
End Function
End Module I receive an error in line:
CODE
With best regards
Michael
RE: Add body to reference set
CODE
If refSetExists Then referenceSet1.AddObjectsToReferenceSet(BodyArray) ElseAt this point in your code, the referenceSet1 variable doesn't actually refer to any reference set; I'd guess that you are getting a "null reference" error. It looks like ref_temp does hold the desired reference set, so you could use that variable or update the referenceSet1 as needed.
www.nxjournaling.com
CODE
Like You write, I didn't have reference to referenceset1, so that's why the code doesn't worked. When I set:
CODE
The code now works correct. Thanks @cowski for Your support.
I tried many ways to solve this, but didn't think it's that simple. I tried figure out what selectedObjectsArray return:
CODE
In my next step I would try something with tag object, but now I don't need to. Thanks again for Your help.
With best regards
Michael
Interesting tool, tagging along on it...
I made the same correction as Cowski mentioned, however the error remains for me.
CODE --> VB
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Imports NXOpenUI Imports System.Collections Imports System.Collections.Generic Module Ref_Ambient Dim theSession As Session = Session.GetSession() Dim sel As Selection = NXOpen.UI.GetUI.SelectionManager Dim myRefSetNames As New List(Of String) Dim ref_temp as ReferenceSet Dim workPart As Part = theSession.Parts.Work Dim dispPart As Part = theSession.Parts.Display Sub Main() Dim referenceSet1 As ReferenceSet Dim selectedObjectsArray() As NXObject Selectbody(selectedObjectsArray) Dim BodyArray(selectedObjectsArray.Length - 1) As DisplayableObject For i As Integer = 0 To selectedObjectsArray.Length - 1 BodyArray(i) = CType(selectedObjectsArray(i), DisplayableObject) Next If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If myRefSetNames.Add("AMBIENT") For Each tempRefSetName As String In myRefSetNames Dim refSetExists As Boolean = False For Each tempRefSet As ReferenceSet In workPart.GetAllReferenceSets If tempRefSet.Name.ToUpper = tempRefSetName.ToUpper Then refSetExists = True End If If tempRefSet.Name.ToUpper() = "AMBIENT" Then ref_temp = tempRefSet ref_temp.SetAddComponentsAutomatically(true, true) end if Next If refSetExists Then referenceSet1.AddObjectsToReferenceSet(BodyArray) Else referenceSet1 = ref_temp referenceSet1.SetName(tempRefSetName) referenceSet1.SetAddComponentsAutomatically(True, True) referenceSet1.AddObjectsToReferenceSet(BodyArray) End If Next myRefSetNames.clear() Dim changeBodytransluency As DisplayModification = theSession.DisplayManager.NewDisplayModification() With changeBodytransluency .ApplyToAllFaces = true .NewTranslucency = 0 .NewFont = NXOpen.DisplayableObject.ObjectFont.Solid .NewWidth = DisplayableObject.ObjectWidth.Two .NewLayer = 190 .Apply(bodyArray) .Dispose() End With End Sub Sub Selectbody(ByRef selectedObjects As NXObject()) Dim ui As UI = NXOpen.UI.GetUI Dim message As String = "Select body" Dim title As String = "Selection" Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly Dim keepHighlighted As Boolean = False Dim includeFeatures As Boolean = False Dim response As Selection.Response Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim selectionMask_array(1) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_component_type .Subtype = UFConstants.UF_component_subtype .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End With With selectionMask_array(1) .Type = UFConstants.UF_solid_type .Subtype = 0 .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY End with response = ui.SelectionManager.SelectObjects(message, title, scope, _ selectionAction, includeFeatures, _ keepHighlighted, selectionMask_array, _ selectedObjects) If response = Selection.Response.Cancel Or response = Selection.Response.Back Then Return End If End Sub Public Function GetUnloadOption(ByVal dummy As String) As Integer GetUnloadOption = NXOpen.UF.UFConstants.UF_UNLOAD_IMMEDIATELY End Function End ModuleError comlains on line 65 in code which is;
CODE --> VB
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
I compared Your code with mine, and You don't have line to create reference set, which should be:
CODE
That's why You receive an error. I also added this
CODE
before
CODE
so I'don't have to place it twice in code - first if ref. exists and second if not.
With best regards
Michael
