Rubber properties under isostatic pressure
Hi guys.
I wonder if you have any idea if standard NBR70 rubber will stiffen significantly under high isostatic pressures?
The rubber in question is used on a ultra deep water ROV, which operates at 6000m depth. We are wondering if the rubber changes properties when the pressure is about 60MPa?
