Changed computer's 'locale' now get annoying message in SE12
Somehow, sometime, unbeknownst to my computer's local was changed to Canada. I created several assembly projects.  Since I've now changed it back to the good ole USA, I get a message that the "locale created in not the same as the current locale" everytime I open the projects.  Is there any way to shut that off?  Saving in the current locale doesn't help, and searching SE's help file does not have the word "locale" ANYWHERE!
RE: Changed computer's 'locale' now get annoying message in SE12
Look at the ...Program Files/Solid Edge V12/Custom/Changelocale folder. There is a macro called Change Locale, which allows you to change the CreationLocale property of Solid Edge documents. The readme is included, too.
Bye Petr B.
