ASME B16.9 wrought Tee with weld within it
Section 1.3 of ASME B16.9 specifies the following:
“Fabricated laterals and other fittings employing circumferential or intersection welds are considered pipe fabrication and are not within the scope of this Standard.”
If two halves of a large tee are forged then welded together with 100% radiography of the weld is there a way of allowing the Tee to remain compliant with ASME B16.9?
RE: ASME B16.9 wrought Tee with weld within it
Refer interpretation 1-3
Link
