Involute Curve in NX 9
Hi! I have gotten access to a file "involute_curve.prt" and was wondering if you could help figure out how to change it. I am unsure what 't' represents. I am fairly certain 'r' is my generating radius. Can you help? Please and thank you! - Kim
RE: Involute Curve in NX 9
Don't mess with the 't' expression! It's value in under the control of the Curve function.
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
The involute curve is a parametric equation (a "law curve" in NX terminology). The "t" is the parameter that ranges from the value of 0 to 1 that helps drive the curve definition. The "t" must appear in the equation for the curve, but as JohnRBaker points out, it is under the control of NX.
www.nxjournaling.com
Ok - T expression untouched! :)
Why can't i use the extrude function and have this involute as the driving curve to build it?
You should be able to do that. Does it give any sort of error message?
Yes, invalid string.
I had used the part file as a linked composite curve and it failed. So I went into the part itself and chose the law curve and it had the same error.
Can you post a link to the involute_curve.prt file or attach your file?
I am using NX 9 and can not open that file SDETERS.
If the "turns" parameter is set to 2.55 or less, it works. I'm not sure why it won't accept a larger value...
That was a limitation which I personally found and reported as a PR, and which I was under the impression that this was fixed in either NX 10.0 or NX 11.0
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thank you for all the input!!! After the holiday I will be looking into this further to see if the involute part i downloaded can actually work with what we are designing! :)
If the Law Curve approach isn't working, there is an alternative. If you look in some location like C:\Program Files\Siemens\NX 10.0\UGOPEN\SNAP\Examples\More Examples\Gear on your system, you will find a SNAP program that creates simple spur gears. Part of this is the construction of an involute curve.
Try change the start angle from 0 to say, 0.1 or 1 or ...
It will probably do the trick, if you can accept it.
Tomas
