"Correcting" an SN curve for a different % probability of survival?
To all
I am looking for some suggestions / explanation on the following. I came across a simple fatigue estimate in a report. What I don't really understand is the "correction" of the SN curve from the data in MMPDs for 84% probability of survival. MMPDS is giving the SN curve for 50% probability of survival (I believe) and it was somehow corrected for a higher probability of survival. The infinite life is therefore much lower (and so is the life at N=1000cycles)
1. How is this done? Is there a formula for that?
2. why 84%? that's 16% failure I suspect
Any ideas
Any ideas
RE: "Correcting" an SN curve for a different % probability of survival?
to change to an 84% life curve, you'd need to assume a normal (or some other) distribution of the population, and assume a standard deviation (or some other parameter to define the population distribution. Once you've done that I think it's an easy statistics exercise to determine the 84% curve (lower than the 50% curve).
again, seems an "odd" thing to do ...
Scorrected = S50%*10^SE*SD
where
SE = Standard Error
SD = Standard Deviation
I am no sure but I think 84% probability of survival corresponds to -1 SD from the mean
Taking MMPDS data as an example, the SN curves are 50% (survivability!) and the doc provides some info on SE & SD. See attached snapshot. Not sure how to read the data though! Any ideas?
My sense (and I'm no expert on this) would be to calc the mean life (well, log (life)) and factor log(life) (divide by 1.18 to get -1 SD ?) and then life (=10^log(life)) and then safe life=life/4 ??
then what does one do with the Standard Error (SE) quoted with the data?
Maybe what they're saying is they can accept 1 in 6 failing in-service ?
Notice how similar the results are ...
with SF = 4 applied to mean life = 12,500 cycles
applying 84% survivable factoring, life = 9,856 cycles
Maybe you're looking at someone else's calcs, and this is what they did ?? seems overly conservative (to apply the SF on top of the 84% reduction).
The only thing I'd change is "N factored" should be IMHO "N reduced" or "N 84%" or "N 5/6"
new life = mean_life^(1/1.18) ... I think !?
so this'd work into the logNf equation ... by dividing the constant (20.68) and the factor (9.84) by 1.18
more importantly, I wouldn't apply a safe life factor to the resulting 84% life ... I think 84% life equates to safe life, and explains why to do it in the first place !
the "shifted" SN curve is log(N)= 20.68-m*Log(S) - Z*SD
where SD is provided (1.18) and Z is the Normal quantile (Z = 1.0 for about 84% survival rate)
for 2 selected lives N0 & N1 get the S0shift & S1shift
did the exercise with N0=1000 & N1=10^8 (with R = -1) and the shift seems reasonable (the slope of the SN curve is conserved)
