Painting over coal tar
Hello everybody,
I got below query and I need some expert advise. Thanks in advance for your help.
"Line pipes (available surplus) is with coal tar epoxy coating which is suitable for underground installation. The same pipes needs to be installed above ground suitable.
Aboveground installation should be suitable for withstanding solar temperature design of 85C. Is it possible to paint without removing coal tar. In such case what is the suitable paint for the same."
RE: Painting over coal tar
Dik
Dik
For anybody to help you more information is required.
1. Where geographically is this project located?
2. Is there more than one above ground portion?
3. How long is each above ground portion?
4. Why do you want to paint over a "coal tar epoxy coating" that will not last?
5. Have you considered any other options (say Cladding as is used with Insulation)?
Sometimes its possible to do all the right things and still get bad results
