NX8.5 - Reusable Sketch - User Defined Expressions ??
Hi.
I'm trying to create a reusable Object from a sketch which I have constrained using 4 User Defined expressions, but each time the defined expressions & constraints are omitted. sad
This is what I've tried
Tools >> Reuse Library >> Define Reusable Object.
Type: 2D Section
Folder: 2D Section Library >> Metric
How can I get the UDE constraints to export with the sketch?
Really appreciate a little help here.
Thank you
J
RE: NX8.5 - Reusable Sketch - User Defined Expressions ??
Would Not that be a File Import?
Hi designnews.
I don't think so. Here is a link to a youtube video which shows the process without UDE constraints. I know it's possible. I've seen it done before including the User defined expression constraints, but can't figure out what I'm missing.
Link
J
