Transformer humming
Transformer humming
50kva transformer supplying battery charger system start making a loud humming sound with load and. With noloaf ,transformer insulation resistance is high,but when using scope meter,output currents was distorting any help
Wave form
http://files.engineering.com/getfile.aspx?folder=d...
Wave form
RE: Transformer humming
The wave form you sent doesn't show lower harmonics (3,5,7).
the picture i attached is for out put current when charger was connected.battery charger is 40kva used as UPC
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
