PasteSpecial As Result CATVBA not working
Has anyone had any issues with "CATPrtResultWithOutLink" to paste "AsResult" not working? I'm trying to paste a product into a newly created product but nothing gets pasted in. Using "CATPrtCont" to paste "As Specified In Part Document" results in an error.
here is a quick example code:
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim productDocument1 As Document
Set productDocument1 = documents1.Add("Product")
Dim product1 As Product
Set product1 = productDocument1.Product
product1.PartNumber = "MyNewProduct"
Dim oSel 'As Selection
Set oSel = CATIA.ActiveDocument.Selection
oSel.Add partCol.Item(i)
oSel.Copy
Dim newSel 'As Selection
Set newSel = productDocument1.Selection
newSel.Clear
newSel.Add product1
newSel.PasteSpecial "CATPRTResultwithoutlink"
'newSel.paste
'newSel.PasteSpecial "CATPrtResult"
'newSel.PasteSpecial "CATProdCont"
newSel.Clear
oSel.Clear
RE: PasteSpecial As Result CATVBA not working
what is partCol.Item(i)?
Eric N.
This was only a snippet of the code but basically I have the user select some data and add it to a collection, then the user could select more data and is added to the collection. Then the collection is copied and pasted into the new product.
http://excelspreadsheetshelp.blogspot.com - http://scripting4v5.com
do you add osel.item(x).value to the collection and you have product in your collection or you add osel.item(x) to the collection and you have selectedelement in your collection ?
Eric N.
Here is the full code to show how the parts are selected by a user, added to a collection, then hopefully copied and pasted into a newly created product.
'filter what to select
Dim filter(0)
filter(0) = "Part"
'select the parts
Dim theOldPart As String
Dim partSelection
Set partSelection = CATIA.ActiveDocument.Selection
partSelection.Clear
theOldPart = partSelection.SelectElement2(filter, "Select the Old Part or hit ESC to cancel.", False)
If theOldPart <> "Normal" Then
MsgBox "ERROR: Problem with the selection. Cancelling the program.", vbCritical, "No CATPart Selected."
Exit Sub
Else
End If
'--save the old part in a collection for use later
Dim partCol As Collection
Set partCol = New VBA.Collection
partCol.Add partSelection.Item2(1).Value
'-----------create new product-------
product1.PartNumber = "Compare" & VBA.Format(Now(), "yyyymmddHhNnSs")
Dim OldPartData
Set OldPartData = partCol.Item(1)
Dim i As Integer
For i = 1 To partCol.Count
oSel.Copy
newSel.Clear
newSel.Add product1
newSel.PasteSpecial "CATPrtResultWithOutLink"
newSel.Clear
oSel.Clear
Next
check chm file about container and PasteSpecial option.
you can't PasteSpecial "CATPrtResultWithOutLink" or PasteSpecial "CATPrtResult" in a product but in a part only.
Eric N.
