Simulating LD45 foam in a drop test
Hello, I currently have the need to carry out a drop test of a case with an internal foam cutout that supports a customers product with the view to find the accelerations excreted onto the product supported by the foam inside the case.
This is a customer request and am not sure if this is going to be something that's possible. Any advice is welcome!
RE: Simulating LD45 foam in a drop test
Definitely possible, just make sure that your solver can model foam and is capable of performing time-dependent analysis. Two methods are:
-Explicit analysis such as LS-DYNA
-Implicit-transient analysis
We previously evaluated a carry case to demonstrate software capability. If required we could recover accelerations of the contents of the case
https://www.xceed-eng.com/5-reasons-to-use-fea-ove...
Jeff
Pipe Stress Analysis
Finite Element Analysis
www.xceed-eng.com
