Help or Advice needed in converting LRA to XZY format
HI everyone, I have a few bend table physical card and would like to enter them into a 3D model using Solidworks, the bend tables are in LRA (YBC) format. I understand most of the data on the bend table but it is the rotation that I am having problems on. The rotation angles on this one are in negative degrees. I do not know where to pick up the rotation from.
Is there a free program, converter or calculation that I can use to get this bend table into an XYZ format. Thanks in advance, Carlos.
Point---Length---Rotation---Angle---CLR
1 .______3.5______ 0 ______ 90____ 6
2 ._____2.897_____ 0 ______ 46____ 3
3 ._____4.697____ -91.67 ___ 47 ___ 3
4 ._____1.311____ -138.89 __ 30 ___ 3
5 ._____3.816____ -181.44 __ 27 ___ 3
6 END.__1.880
6 END.__1.880
RE: Help or Advice needed in converting LRA to XZY format
Dan - Owner
http://www.Hi-TecDesigns.com
You might try calling a company that makes benders or that fabricates bent tubes. The machine controllers often take in data in either format and can produce a chart in either format. The reason they can do this is the LRA is what is used to operate the bender and the XYZ is often used to inspect the finished part.
