Non-circular flat head
I am performing a code analysis on a shop made "vessel". It is basically a piece of 3" Sch 10 SS pipe with two 5" x 7" rectangular flat heads welded on each end. Two 1/4" AN910 couplings are attached to each head for nozzles.
The head joint configuration matches UW-13.2(e-1). My question is, for determining the required flat head thickness per UG-34 and opening reinforcement per UG-39, would just use the diameter of the portion of the flat plate that connects to the shell (outside diameter of the pipe) or would use the equations that account for the long and short spans of the rectangular head even though the entire head is not under internal pressure?
RE: Non-circular flat head
Mike
prex
http://www.xcalcs.com : Online engineering calculations
https://www.megamag.it : Magnetic brakes and launchers for fun rides
https://www.levitans.com : Air bearing pads
