Search/Get "Text" value inside Definition property of 3D Annotation Set
Hello All,
I am able to select "ENG" property in 1st picture below as per my short macro below. However, I do not know how to search and get the text (i.e. PLATE) in the definition of "ENG" as seen in second picture below.
Please help me out.
Picture 1:
DEFINITION OF "ENG" property
Picture 2:
My short macro
Sub SEARCH_PLATE_IN_NOTES()
Dim oSel As SELECTION
Set oSel = CATIA.ActiveDocument.SELECTION
oSel.Clear
oSel.Search ("Name = ENG*, All")
MsgBox "HERE" '// Indicates macro got to this point
End Sub '//// End of this Subroutine
Thank you in advance
Please help me out.
Picture 1:
Picture 2:
My short macro
oSel.Clear
RE: Search/Get "Text" value inside Definition property of 3D Annotation Set
CODE --> VBA
CODE -->
CODE -->
if you need the string then use
CODE -->
I now get to the text string display on the monitor as per your code above: myTextasString = CATIA.ActiveDocument.Selection.Item(1).Value.Text.Text
But how can I search/obtain above text stream for word "PLATE" or any other word (as strings) in the text stream accessed above?
Is there any CATIA command or macro method to achieve this?
