Convergence problem when including residual stresses
Hi, I am modelling a simple plate structure and compressing it by applying an initial displacement to the master set tied to the left side of the plate using the equation constraint. When including the residual stresses by typing initial conditions, type stress, the error, 'time increment required is less than the minimum specified' arises. I am unsure how to solve this problem. I've attached an input file. Do help me!
RE: Convergence problem when including residual stresses
2. Why are you using Riks?
