Impact test B31.3 for CS
There is method in ASME B31.3 for MDMT reduction by using Figure Fig 323.2.2b base on stress ratio. However, if applying this method, the Code requires the material shall be isolated from any impact loads.
My question: if the line is outlet of PSV or has two phase flow, shall it be forced to impact test even Fig 323.2.2b says OK for MDMT reduction??
RE: Impact test B31.3 for CS
1. Technically, it isn't actually 'reducing' DMT, it's a provision for the setting of a DMT below the allowable minimum temperature value for the material;
2. The answer to your question is: it is up to the owner/designer to ensure that it is acceptable to deploy the measures stipulated in the standard accounting for all feasible scenarios.
Thus, it becomes a case of assessing what failure modes may occur, whether they are tolerable as is, or whether impact testing can serve to provide a suitable barrier to an unacceptable top event resulting from the failure mode.
One possible failure mode to consider could be cracking from thermal shock in a constrained piping system, for example.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
