Add/Remove load steps in Ansys Mechanical (WB)
In an analysis with multiple load steps (>10), is there a way to add
a new load step in between the old load steps?
Also is there a way to delete a specified load step from analysis?
Thanks in advance.
Thanks in advance.
RE: Add/Remove load steps in Ansys Mechanical (WB)
Generate Restart Points = Manual
Retain Files = All
Retain Files After Full Solve = Yes
After the initial solve, you could then change the in-between load step as you described (e.g. 5) and restart from the previous load step (e.g. 4).
The only way I know how is to reduce the number of steps. Doing so shouldn't remove any saved lower number restart points.
Best regards,
Jason
