Motor Torque From website
Hello
I'm having a bit of trouble determining the total output torque of this motor that I found online.
It has a motor attached to a gearbox.
http://www.anaheimautomation.com/products/brushles...
On the website it said to "Torque of the output shaft (after gear-box) = (Peak Motor Torque) X (Gear Ratio)"
(There are two peak torques, one on each chart but I'm guessing I should use the first chart's torque ratings. What would the second torque represent then?)
I would like to know not only the peak torque but also the rated torque.
How can I find the rated torque?
Thank you
Thank you
RE: Motor Torque From website
Leading onto this question, how would you find the rated torque for this motor? This time, would you use chart #2?
Thank you
