Hastelloy Sheet Metal
Good afternoon, everyone. I'm not sure if this is the right section to ask this question but I thought I'd give it a try. I am trying to find a sheet metal supplier of:
UNS 26455
9.4610 Hastelloy C4-C
ASTM A494 CW2M
DIN G-NiMo16Cr16
I have searched online with no luck except for one company which has yet to answer my call/email. Has anyone had to deal with this before? What are my best options to locate a supplier located in the US or Europe?
RE: Hastelloy Sheet Metal
This product should not be difficult to find. You may try your luck here.http://www.thomasnet.com/.
Thanks.
Pradip Goswami,P.Eng.IWE
Welding & Metallurgical Specialist
Ontario,Canada.
ca.linkedin.com/pub/pradip-goswami/5/985/299
You have numbers confused.
N26455 and CW2M are casting designations.
If you want wrought sheet then N06455 is the correct UNS.
You could try Haynes, or Special Metals, Rolled Alloys, or Ulbrich
Quote (edstainless)
Maybe this is why I was having problems. I reached out to Haynes, Special Metals, and so far the only one that may have it available in stock is Zapp in Switzerland. Awaiting their contact. Thanks for the information though Ed, I was reading from the engineering material spec and didn't even think to check if they knew the correct numbers.
