Modicon TSX Premium PLC Fault
Hi ALL,
We have a fault on the modicon PLC and I am trying to figure out the error
On the power supply module[TSX PSY1610]-Ok LED is ON and red "BAT LED" is on-what does that mean?
On the processor [TSX P57104]-RUN LED GREEN ON and I/O LED ON-what does this mean?
On the local HMI it's displaying "Low PLC Battery Alarm"
I am looking for the correct software to talk/connect to the PLC
Can Unity Pro XL talk to the TSX P57104 processor?
Need assistance
Chris
Need assistance
Chris
RE: Modicon TSX Premium PLC Fault
*care must be taken when replacing the battery not to turn off the power supply.Do not turn off power supply to PLC.
Usually the PDFs are broken down into: installation manuals, user guides technical guides, PLC programming instruction manual, etc.......
I think all your questions can be answered by this method. As an example I googled your part numbers and downloaded a pdf at below link.
http://fi.snb.leon.se/Downloads/PDF/DIA6ED2040203E...
https://www.modiconplc.com/schneider/TSX-Series/cp...
Chris
