gui for fortran code
hi, I have a fortran program which takes data/input from .csv file . is there a way to feed the data to this program via a gui? so, the GUI window should open first, and then figures/data entered here should be used for the program.
thanks
RE: gui for fortran code
thanks.
for my program, I feel gui interface would be better.. I am using codeblocks. I just want to know how I can develop a gui around this
I thought something like Visual Fortran would have a GUI option, but there appears to be other options as well: http://fortranwiki.org/fortran/show/GUI+Developmen...
http://www.winteracter.com/
TTFN (ta ta for now)
Quote:
Why? I personally hate interfaces like that. Better that there's a spreadsheet I can use, and the import the sheet, particularly if there are a lot of values to enter
I'd say Excel is a GUI!
The link below gives details of how to run any .exe file from Excel, using VBA:
https://newtonexcelbach.wordpress.com/2016/06/30/r...
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
@IDS, I don't wish to run the exe from excel, instead wish to develop an independent GUI for my program
Which Fortran compiler are you using? Both Salford and IVF/CVF have built in functions for creating GUIs. I don't know about IVF but CVF didn't have the latest widget set. It just has a basic widget set.
Alternatively you can use something like dislin or winteractor
I am using GNU fortran compiler which was default in codeblocks.
There is also GTK/Fortran, here
