Exporting drafts from every part of an assembly to pdf
Hello
Is it possible if I create a 3D assembly containing different parts, that each have their own draft in their draft application, and from that assembly export every part drafts at once into pdf without haveing to go into every part individually to export to pdf. And as a bonus if those pdf could be exported in one bundle after the assembly draft.
I am using NX 10
I don't have teamcenter
Thank you!
I am using NX 10
Thank you!
RE: Exporting drafts from every part of an assembly to pdf
www.nxjournaling.com
