Transmission Tower Collapses
from the CBC, "In the wake of a fatal transmission line tower collapse in Newfoundland and Labrador, the Manitoba Federation of Labour is calling on Manitoba Hydro to make sure workers doing similar work in this province are safe.
"I hope these things are being looked at seriously and I'm very fearful," said MFL president Kevin Rebeck, worried that the accident in Newfoundland could be repeated in Manitoba. 5 Manitoba Hydro transmission towers collapse during assembly.
Condolences pour in as Forbes Bros. confirms 2 employees killed in transmission tower collapse. Two workers died Monday when a steel transmission tower collapsed while being built near Come by Chance, N.L.
Manitoba Hydro has had five transmission towers collapse between February and May this year, although there were no injuries reported in the Manitoba incidents."
There have been large staff cut-backs at Manitoba Hydro of late.
Dik
Dik
RE: Transmission Tower Collapses
Edit: Around 30 to 50 workers in every 100, 000 are killed on the job every year.
http://www.tdworld.com/transmission/utility-line-w...
I was climbing down a series of ladders to inspect the connections of a grating floor that had been damaged by a hydraulic ram. When I hit the landing, it wasn't there... I nearly choked from my heart going into my throat... the area was poorly lit, but, it was only my means of climbing that saved me from going down another 30 or 40 feet...
Added: Manitoba Hydro is an exceptionally safety conscious organisation... and these fatalities are the exception.
Dik
They are all harnessed to the platform, right?
JHG
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
That suggests to me that there's a major problem with either the design or the materials, or the method of construction. These towers have been built for decades, what's the problem now?
That said, I know there was a component, an angle bracket or such like, that was sourced from India for the Newfoundland job, and EVERY SINGLE ONE of them was being re-worked locally because of faulty workmanship. I wonder if there is a connection.
Were the transmission lines being installed, or were the failures prior to that loading?
Lots of questions, but few answers.
Mike McCann, PE, SE (WA)
Is this what happens when one guy climbs up and can't figure out how to get down, so another goes up to help, and then also gets stuck? Judging from the relative lengths of the beards it seems to have taken a few days to convince the last couple of workers to climb up there.
Or is this a version of a time-out for playing practical jokes on the work site?
A heli would have blown them away...
Otherwise, by looking at the photo it appears that there is an end plate with bolt holes that they are standing upon - waiting for a further extension.
The all were waiting for the next pipe section to come but then realized that they had nowhere to stand while they placed the next section.
So they sent in a Request for Information (RFI) to the designers and are simply waiting the prescribed 3 days to get an answer back.
Might be a week until they get a construction engineer to design a temporary walkway around the flange plate for them to stand on - all OSHA approved.
So until then they might use some sleeping bag slings hanging off the top.
Dik
Irvine, CA
Siemens PLM:
UG/NX Museum:
Dik
Irvine, CA
Siemens PLM:
UG/NX Museum:
Dan - Owner
http://www.Hi-TecDesigns.com
Irvine, CA
Siemens PLM:
UG/NX Museum:
https://www.youtube.com/watch?v=Qtg-PB_j33s
