Removing parameters(associativity) of intersection curves inside sketch
Is it possible to remove associativity of the intersection curve in sketch? We can toggle of\on in project curve or extract curve, but that option is not available in intersection curve(inside sketch environment). Thanks in advance.
I am using NX 9.0
I am using NX 9.0
Ranjith P R
Automotive Seatings
RE: Removing parameters(associativity) of intersection curves inside sketch
Not in direct way.But by trimming or extending or moving the objects inside the sketcher you can.
regards,
Mathi Krishnan
NX11.0.0
