Engineers Handbook - Different Clearance Holes
I have noticed in the engineers handbook (30th ed) there are a few instances where clearance hole sizes are tabulated for inch fasteners. For instance, in the section Fasteners -> Metric Threaded Fasteners -> Clearance Holes for Bolts, Screws, and Nuts (p. 1659) there is a table that uses ASME 18.2.8 for clearance holes. In another section, Fasteners -> Cap and Set Screws -> Drill and Counterbore Size (p. 1733) the clearance holes for the counterbores are listed from ASME B18.3 and are different than the previous table. Furthermore, in section Threading -> Tapping and Thread Cutting -> Tapping Drill Sizes -> Clearance Holes (p. 2093) the listed clearance holes are different than the previous two tables.
I noticed that my CAD program (SolidWorks) uses the third mention table for all clearance holes (simple hole, counterbore, countersink) and so do most other tables and posters I see in shops. I'm just looking to see if anyone can provide some clarity as to why there is a variety listed. For instance, why does ASME state different clearance holes in B18.2.8 and B18.3?
Thanks in advance,
Greg
Thanks in advance,
Greg
RE: Engineers Handbook - Different Clearance Holes
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
@JohnRBaker yes and they each list different classes of 'fits'. The first table lists Close, Normal, and Loose fit. The second table lists Close and Normal fit. And the third table lists Close and Free fit. But the majority of them don't match up. Below is an example for a #4 screw clearance hole (drill sizes listed)
Close Normal (Free) Loose
Table 1 #31 #30 #27
Table 2 1/8 #29
Table 3 #32 #30
I know they are all pretty close, just wondering if anyone knew the reasoning - or if it is as simple as we just have a variety of the same standard :)
Table 1:
Close = #31
Normal = #30
Loose = #27
Table 2:
Close = 1/8
Normal = #29
Table 3:
Close = #32
Free = #30
It has to do with all the related considerations such as: how precisely you want the holes to position the screws, what kind of tooling and skill levels are available, how many holes there are in the pattern, and many others. For example, let's you have a lot of holes in a pattern. If you know they will be laid out by hand with a tape measure, you might go with larger clearance holes just to allow absorption of the unavoidable inaccuracies and variations, so the assembly guys don't have to spend half the day filing out and resizing holes just to get them to fit. If however you know the layout will be done on a CNC, then you know the positions will be more accurate, and you can go with smaller clearance holes. The various "standard" just assist the engineer in applying his judgment to the particular situation. That's why standard clearance holes in structural steel work and in tool and die work are two very different things. Think of the environment (tools, skill levels, assembly practices) in which they are created and used.
Standards are very important, but they should not replace the human judgment of the engineer.
This is why you just do your testing first and write your protocol afterwards...
B18.2.8 and B18.3 control different types of fasteners with different threads and the necessarily different clearance holes as mentioned above. It may seem arbitrary to many engineers who have little/no background on the shop floor, but the couple thou difference in major diameter between a class 2 and class 3 thread of the same pitch can create all manner of issues downstream of design if standards are applied improperly.
In aerospace we classify holes by the application, and some of us actually refer to holes as "class 1" through "class 4" or "5" depending on which reference you're looking at (I can see MintJulep pointing his/her finger already). For any given standard fastener size there are then given a min/max to specify in the tolerance limits, suitable for a particular application. For instance, if installing a structural part with shear-loaded 1/4" fasteners, a Class 1 or Class 2 hole might be called for, leading to a tolerance approximately [0.250/0.254] inch, but if the application is a light bracket that could be removed repeatedly or has lots of holes that must all freely line up, then a class 4 hole would be applicable, and then the drawing has a tolerance on the hole more like [0.265/0.274]. Not only is the hole larger but the tolerance band is looser, too. Know when you can make the part cheaper.
Notice how we are not specifying the drill size to be used. We are relying on manufacturing to select the right drill for the job.
What we are actually providing here is the pass/fail criteria to our inspectors who will use the drawing to accept/reject the finished part.
To be a bit more pointed about it: we are not taking responsibility for telling manufacturing how they should make the hole.
If they want to use a router with a 1/16" pin to cut a circular path, then by all means they can, but a short sharp E bit will do, too.
They sometimes complain because we are not telling them step-by-step what to do, but if we give in, we will be tying their hands and they'll complain about that even more.
STF
Specifying the tap drill is an explicit way to get the finished hole one wants. There is enough range to allowable minor diameters that several different standard drills can be used to get the desired combination of thread strength and ease of tapping. One might go with a larger drill with slightly lower strength requirements to speed tapping and increase the rate of production/minimize the wear rate of taps. Alternatively, go with a smaller drill to maximize the strength. It should not be left to a factory floor guy to become an ad hoc part of the engineering design process.
As for the original question, I noted that the tolerances for drilled holes in the Machinery's Handbook chart indicated it was from drilling a hundred holes of each size into iron and measuring them. Which means they really don't apply to other materials, such as aluminum, but people use the same tolerances as if they do. The chart also fails to mention if this was a 3-sigma range or just the range they got for that sample. Doesn't matter - people copy and paste and don't read the fine print.
I expect the same is true of the clearance hole charts. Someone did some experiment, gathered some data, and it got published. If the actual reasoning/method is not part of the chart, then the contents fall back to a default of not being so bad that people stop using it. Without backing the particular values are otherwise meaningless.
Required clearance is a matter of all the factors that affect the structural need for the fastener, too many to care to list, and manufacturing capability. The chart just gives an out for avoiding evaluating the situation. If the fasteners don't fit, they'll just drill the clearance holes bigger anyway.
It may seem trivial to office staff but as parts must be made to print or rejected, nonstandard combinations of tap/drill/clearance/head/point geometry create all manner of issues that quickly drive up cost. Many production shops use combination tools, spec something nonstandard and the drill, tap, and clearance geometry become three separate operations with three separate tools rather than one. Even if the shop runs individual tools/operations, spec'ing a nonstandard hole often means additional machine setup time to change tools and certainly will mean additional inspection, again time and cost. It also increases the risk of mistakes causing scrap and most suppliers will charge accordingly, 30% premiums on parts that need special manufacturing is very common as is additional charges like material profit markups, tool markups, etc that would not be charged otherwise. Internally, manufacturing engineering may decide to spec a pilot drill or tooling for various reasons but they will do so on manufacturing markups and process sheets, not on the design print in case the part is outsourced in future years.
Standards are meant to simplify life throughout the value stream and help keep costs low. You're welcome to deviate to improve the design but there are many risks associated with doing so and its not something that should be done as a matter of habit or laziness or you are needlessly adding cost and risk.
If the risk is from working with a 1-sigma shop (30% fail rate) then that's an avoidable one. If forced to work with such a shop, then nothing will help. I say that as having worked with a shop of that capability. One time they broke two taps in a hole. It was tap-drilled for a 1/4-20 hole. Then they grabbed some 1/4-20STI taps. No fixing that on the drawing.
Irvine, CA
Siemens PLM:
UG/NX Museum:
