1" thickness pipe to be with notch toughness procedure.
we have to weld we have to weld 1" pipe with notch toughness procedure.
i do have welding procedure up to 3/4" weld.
can i used two welders with this procedures to weld 1" thick.
i do have welding procedure up to 3/4"thickness weld.
can i used two welders with this procedures to weld 1" thick pipe.
so first welder can weld 0.5" thick both side & other welder can weld remaining 0.5"weld.
please advice
stanly
please advice
stanly
RE: 1" thickness pipe to be with notch toughness procedure.
If the weld is 1" thick, it's 1" thick, and you can't just treat it as two welds 1/2" thick.
Having two different people weld on it is not a problem, but it's still one thick weld, not two thin welds.
The various welding codes will specify how thick the weld (or material) can be, based on the thickness used in the weld qualification and in the welder certification tests.
