Fasten Plywood to Steel Bar Grate
The general contractor wants to fasten 3/4" plywood to steel bar grate.
Here are my thoughts:
https://res.cloudinary.com/engineering-com/image/upload/v1497971205/tips/Plywood_To_Bar-Grate_wux6xp.pdf
Any other options?
Thank you!
Any other options?
Thank you!
RE: Fasten Plywood to Steel Bar Grate
jayrod... I also think plate is cheaper. My current ideas are 4-step. I'm hoping there is a simpler, quicker, one or two step process with TEK screws or other.
