Running Multiple Jobs via command Prompt
Hello Everyone,
Can someone let me know,if it is possible to run multiple ABAQUS Jobs at a time via command prompt
As of now,I am using the following command:
abaqus job=Job-1 cpus=4 int ask_delete=OFF
Here,Job-1.inp is my input "INP" file.Now,Can I run multiple jobs in this command?
Thanks in Advance!
RE: Running Multiple Jobs via command Prompt
You can open a new terminal and run another job. Or if you are not doing an interactive job you can just type the command again with the new job name.
