RPTFE SEAT BALL VALVE TEMP RANGE
Hi
What will be RPTFE seat Ball valve Temp Range. one of the customer is requesting for a Temp of +232deg C.
RE: RPTFE SEAT BALL VALVE TEMP RANGE
If you're just using a design temperature of 232 C and service temperature will be 200 C or below, you will be OK- but the pressure rating of the valve with respect to temperature will depend on its construction. You need the chart offered by the manufacturer, and then to ask the manufacturer what testing or standard they base that graph upon.
