need to correct my errors
Hi All
I need to correct my comments in this thread, since I received two warning of Grammar errors : http://www.eng-tips.com/viewthread.cfm?qid=426517
Shall you please kindly point them out?
RE: need to correct my errors
Probably "I was having" should be "I had". This leads to "I had an interview with a company that makes aluminum extrusions."
"was going to" suggests that in the past you wanted to do something, but never did. Do you mean "I want to"? "I am going to"?
"I am going to" is in the future. I guess this might be your meaning.
"engineering on the past products using a FEM software to make other products" Not clear if you want to use FEM to MAKE other products, or use FEM software that is used in the design of other projects.
"by doing the reverse engineering on the past products" This the job you interviewed for? You are going to do this after the interview for fun? Why? What need does an extrusion company have for reverse engineering their own product? They have the original engineering information.
As you can see, from your first sentence I am reasonably sure that you had an interview with an extrusion company. Right?
Beyond that I can't even make a guess that seems reasonable.
Let's get this first sentence fixed.
