How to do grading around building corners?
I am trying to figure out what would be the best way to do sidewalk grading around the building. In this example, I have building at set elevation and sidewalk around it. Sidewalk has to be sloped 2% away from the building. I was wondering if someone has experience and share what approach would be the best and how to grade building corner area (between points 1,3 - points a,b). What I came up with was a few grade break lines (Pt.3 - Pt. b, Pt.2 - Pt. a, Pt.1 - Pt a). I was wondering if there is a better way to do it?
http://files.engineering.com/getfile.aspx?folder=1...
Thanks!
Thanks!
RE: How to do grading around building corners?
Dik
Thanks.
