Failing retaining wall at existing driveway
So someone contacted me and wanted me to come out and take a look at the condition at his property to see what the potential solutions would be. I have attached a pdf of a cross section through the area of concern.
Basically the owners driveway runs along the side of an existing property line retaining wall that is failing. He contacted the owner of the other property who rents out the house to see if they would share half of the cost to replace the wall and they said no.
As you can imagine my clients concrete is developing large cracks and sinking at areas due to the existing failing retaining wall. So he would like me to design a new foundation system that would support a new concrete driveway without imposing any load to the existing wall as well as still support his driveway if the wall fails.
There are a few options I have and my client will be paying for the solution, so I am just looking to refine the options in favor of an economical design:
Any of the solutions would disrupt the soil behind the existing wall so it would have to be shored up during construction.
I am leaning towards the solution that supports the new driveway on a grade beam and concrete piers, but if the existing wall fails then the driveway would be freestanding and I would have to design the whole system for lateral seismic loading. (Located in Southern California)
Any thoughts and or suggestions would be greatly appreciated.
Thanks in advance.
A new structural slab supported on a grade beam and caissons embedded below the existing wall footing
A new property line retaining wall.
A new concrete retaining wall spanning horizontally between caissons a few feet inside my clients property that extends down to the depth of the adjacent existing retaining wall footing. This wall would be supported by caissons spaced at 9ft on center with the point of fixity assumed to be about a foot below the existing footing
Thanks in advance.
RE: Failing retaining wall at existing driveway
If the wall was for the benefit of the land owner rather than the neighbor, it seems it would be his expense. I would not read reluctance to pay as unwillingness to participate. Neighbor may not mind not paying for a new wall even if construction temporarily encroaches into the neighbor's property.
Just have to ask.
f-d
ípapß gordo ainÆt no madre flaca!
www.PeirceEngineering.com
Have you looked into a geogrid solution? The wall isn't that high which would save on grid material but you would want to be careful with the tight space and the load from the house when you start excavating. Just a thought but it's worth looking into.
Tie backs, soil nails, dead man anchors? There might not be enough room on either side of this wall to install these but you might be able to pour a dead man anchor close to the house and run threaded rods through the wall to stabilize it from moving anymore. Obviusoly this need to be thought of more in depth to see if it possible with the field conditions and access but it's worth a thought. Good Luck!
But as others said, the driveway looks pretty good to me. A photo of the retaining wall face would be helpfull
