I am sizing a RV. I need to determ
I am sizing a RV. I need to determine the rate through a centrifugal compressor. I have the performance curves, which show a design rate of 1500 acfm suction. At times we use the compressor to process material having a higher molecular weight. Should I assume that capacity through the compressor is the same 1500 acfm (assuming the inlet P/T stay the same)?
RE: I am sizing a RV. I need to determ
Determine the orifice size for the required relief flowrate while processing the low MW stream and the high MW stream, and then size the RV for the larger of the two.
George, your comment about allowed over pressure is correct, since the pressure ratio is an important variable in the rate/HP calcs.
