slab on grade
slab on grade
slab on grade
Good evening
I have an assignment to design a slab on grade supported on short columns with height of 1 meter
is it right to design it like flat slab or it has another approach?!
Thanks in advance.
RE: slab on grade
Sounds like an unusual configuration. Perhaps a more detailed description can be provided.
RE: slab on grade
If the slab on grade is supported by the columns (piles?) rather than the grade itself then, yes, it is appropriate to design it like a flat, suspended slab. If you have expansive soils or frost heave issue, be sure to account for upwards pressure.
RE: slab on grade
the OP is confusing. Is it a deck supported by columns or is a slab constructed on the grade of the earth?
f-d
ípapß gordo ainÆt no madre flaca!
RE: slab on grade
https://drive.google.com/open?id=0BxlMokjxG-MTcUY0Vzl3QTZ1TGs
this is a picture for the example
RE: slab on grade
That's no picture of a completed job. Missing is the information s to what these individual shallow footings sit on. Rock? What is the explanation for the combination slab-on-grade and footings?
RE: slab on grade
link's not active.
f-d
